Missing part?? whats it called
Bunnerrabbit
I just noticed this today but my motor is missing the fin piece by the prop. Will this affect much? The small fin piece just above the prop. bolts there but nothing else. I just got the boat. Can you tell me whats this part is called?
tmcalavy
Re: Missing part?? whats it called
If you mean the little triangular fin above and behind the prop, that's the trim tab...you adjust it right or left, make a reference mark first, to get your boat to steer equally easy left or right and to run straight in the water. For example, if steering wheel turns easier right than left, adjust (turn fin to right)...and vice versa. Little adjustments go a long way, though.<br />If you mean the fin under the prop that keeps the blades off the concrete, that's the skeg.<br />Both are must-haves. You can get a trim tab from a dealer or maybe on ebay. If skeg is gone, you'll have to get one welded on.
Bunnerrabbit
Thank you very mcu its the trim tab. I am learning more and more everyday thanks everyone.
