Missing rear Zinc bolt Alpha 1...any issues?
jonny rotten
Smashed zinc to get the bolt out on an an Alpha 1 Gen 1 (the rear bolt)
THe hex bolt from under the zinc is in
Will I have issues with water between the halves without the zinc and zinc bolt. Everything else is bolted tight
I guess what I'm asking is with the bolt in from underneath a half inch away, is the zink bolt really holding anything together?
I only ask because I forgot to get one and I'm boating this weekend, I will be getting one before going out again
Nope, shouldn't,...... except possibly abit of odd spray,.....
Ayuh,..... That's all it does,......
If yer zinc had a torque tab, the steerin' might pull,.....
