1968 Evinrude, 65 Horse - Sport Four
Hi All! New boater here. First want to say what a blessing this site is and also great motivation. I reciently aquired this Lapline and was told it had a new power pack but still needed carb work. To Date I've done... 1) Carb Kit. 2) Compresion test (1/3 90psi) (2/4 80psi). 3) Sparks jump 1/4" on all 4. 4) Decarb. 5) New lower unit seals and impeller. 6) When I pull the plugs on 2 or 4 It dosent make a very noticeable rev drop and both plugs are dark and wet. When I pull the 1 or 3 wires the motor stalls and those plugs look correct-slightly tan and dry. Another couriosity.. When trying to set the lowspeed idle, the PORT side responds as expected but the Starboard needle dosen't make a smooth setting. This would make sense if it was supplying the weak 2/4 cylinders.
Thanks for any suggestions!
