Missing wiring horness
roygtaylor
Have Evinrude 35 Lark modle #03219. Serial number 35616,Need year,<br />Trying to get it running do not have the wiring control cable. Engine was in storage about 10 years can hot wire it to turn. It has a 7 male pin connection, 3uperhalf 4 lower half.
SpinnerBait_Nut
Re: Missing wiring horness
Try to find some more numbers on that engine if you can. <br />Am not showing them numbers in my info.
rolmops
Hello.<br />This a wild guess.<br />Your serial # is really your model# and instead of 35616 it should be 35516.<br />That would make it a 1959 evinrude with a rectangular 7 prong male outlet on the engine.<br />You need a cable with the female of that one to go to a "starter box" that would be on the transom of your boat.<br />Time to buy a manual so you can see everything you need.<br />You can get the stuff at:<br />www.twincityoutboards.com<br />good luck
