Re: Mixing deep cycle and standard batteries
With most other things electrical we have circuit breakers or fuses. Cars have fuses, breakers, or fuseable links. In older boats at least, why do we so seldom have any way to control a short circuit? Toasting your boat is bad whether in your driveway, marina, or on the water. And on the water if there should ever be a short how would you prevent a fire or keep it out once you got it extinguished in the first place? (Like you can just get out and run home?!!!) At the very least there should be a battery switch of some sort, even if for only one battery. Much easier than trying to remove very hot cables directly from the battery. I tried it, didn't like it.
<br /><br />I prefer two deep cycle batteries; I keep one on the outboard and the other for trolling motor- not connected together. The latter gets charged as soon as it gets home. The outboard's gets charged if not used within two or three weeks. I'd probably have the same arrangement for a smaller inboard also so long as I could fit in an adequate deep cycle for starting and could get to it for easy maintenance. The dual purpose batteries are OK, though I think for me the advantages of the true deep cycle outweigh whatever benefit the compromise battery would offer. Properly maintained, a quality deep cycle will outlast a dual purpose battery every time. Aside from Optima and the really high end batteries, maintenance free/low maintenance are only better when you won't be able to keep your battery supplied with distilled water religiously. Comes down to choosing which hassle you prefer, really.
