mixing quicksilver oil and synthetic oil
BENTPROP
I have a tank full of gas mixed with quicksilver. I would like to switch to a synthetic oil - Could I add synthetic oil to the tank when I add more gas??? I will still have some of the old mixture in the tank?? thanks
ZmOz
Re: mixing quicksilver oil and synthetic oil
As long as they're both TCW-3 oil, they will mix just fine. (that's part of the requirements for an oil to become TWC-3 certified)
KCLOST
No problem.... Just mix it properly with the added gas....
quantumleap
You won't see the full benefit of running a synthetic until the diluted mixture is used up though.
phatmanmike
even better, try this.. <br /><br />use up all your regular oil and then "decarb" the snot out of your motor real good with 1 can of deep creep per cylinder and then replace your plugs(with new ones)... then after that is done, switch over to synthetic, and also switch your lower unit to synthetic also at same time, but make sure you do this with brand new fresh gass, you should see a differewnce right away<br /><br />m ikey
quantumleap
That's what I did and there was noticable improvement.
BENTPROP
Thanks for all the help . I plan on going totally synthetic. Even the fabric I wear. This may be a dumb question but - what differences will I notice??
ZmOz
Better speed, less smoke, better gas mileage...<br /><br />All of these things will be really small though...
phatmanmike
any improvment is a good improvment, and i think you know , zmoz, with my big inline 6 , ill take all i can get.<br /><br />motor will run smoother, be quiter, less vibration, better throttle response, less smoke, less wear on your internals such as bearing, cylinderwalls and less carbon build up on your rings.....<br /><br />it makes your motor as close to new as you can get without rebuilding it with new parts!
BoatBuoy
But there's something nostalgic 'bout that smell of burning outboard fuel. 'Specially the 24:1.
ZmOz
Originally posted by BoatBuoy:<br /> But there's something nostalgic 'bout that smell of burning outboard fuel. 'Specially the 24:1.
Yeah, I happen to like the smoke. :D
LubeDude
Originally posted by phatmanmike:<br /> even better, try this.. <br /><br />use up all your regular oil and then "decarb" the snot out of your motor real good with 1 can of deep creep per cylinder and then replace your plugs(with new ones)... then after that is done, switch over to synthetic, and also switch your lower unit to synthetic also at same time, but make sure you do this with brand new fresh gass, you should see a differewnce right away<br /><br />m ikey
Where have I heard this before??
BENTPROP
Hay LubeDude - You told me before but I lost the info -- What synthetic oil has a TCW-3_ rating ??
Paul Moir
BentProp - <br />If you want to find a recent post you made, click on the little man standing next to the box right after your posting date, and then click 'View Recent Postings' on the right of the screen. That will show your last 50 postings.<br /><br /> Oil discussion, click here. <br /><br />To find all your postings if you've made more than 50, click on 'Search' in red above and enter your name or number (43547) into the box labled "Member Number or Public Display Name:".<br /><br />Hope this helps you out navigating Iboats! :)
LubeDude
Originally posted by BENTPROP:<br /> Hay LubeDude - You told me before but I lost the info -- What synthetic oil has a TCW-3_ rating ??
I may stand corrected, but I beleive that Synergyn, Klotz 50:1, Cam2, and of course Pennzoil products. Im sure there must be others.
