Mixing two cycle oils
waterbill
Is it ok to add a different brand of BIA certified TC-W two cycle oil to a reservoir half full of Yamalube? I was looking through some notes I took in an outboard engine repair class years ago, and I had written down "don't mix oils". Too late. I just added a pint of Citgo TC-W two cycle to my engine's internal oil tank. Should I dump the whole thing and start over now? I know this question sounds dumb, but I don't want to make an expensive mistake.
LubeDude
Re: Mixing two cycle oils
The chances of what you did causing any problems is very remote at best. I am not aware of any oil now days that is not compatable with other oils. If it were not I would think it would say on the bottle, IN GREAT BIG LETTERS!
JB
Moving to General Outboard
ZmOz
Yeah, you should be fine since they're both TCW-3 oils. I mixed some Havoline and Pennzoil last year. Only problems came when I didn't mix anything at all. :D
wayne h
it all comes from the same refinarys just diffrent lables u will be fine lol
LubeDude
Originally posted by wayne34609:<br />it all comes from the same refinarys just diffrent lables u will be fine lol
The base stock might, but oil is more than base stock.
seahorse5
One of the TC-W3 requirements is that an approved oil should mix without problems with the reference oil. In that oil test done by Bass and Walleye Boats magazine several years ago, they mixed a number of oils together and looked for any type of reaction; there was none.
199675hpforce
Walmart supertech used to be blue i think it was just like quicksilver now its green? I would not worry about that stuff just put it in there way better than none.
