mixture oil leaks from reservoir thru bottom carburator on 50 hp mercury
barglow
I have bayliner boat 2000 with 50 hp outboard mercury motor. Suddenly i noticed mixture oil only leak from bottom carburator . It is a gravity leak, meaning if i raise motor it leaks more. I suspect something got stuck & dont shut off oil flow. What is responsible for shutting down oil before gets mixed from reservoir while motor is off? Please help me diagnose this problem.
Chris1956
Re: mixture oil leaks from reservoir thru bottom carburator on 50 hp mercury
Is it just oil or is is gasoline/oil mix? If a mix, it is likely the inlet needle is sticking or the float is defective in the bottom carb.
barglow
it is just plain oil
