MK2GR Floor Plans
pistonbroke
Newbie needing help. I was given a Mk2GR/1 in what I'll call reasonable shape, less the floor. Mon/Yr M788 serie 2428. I would like to build my own floor out of marine plywood but lack information..e.g. size, one piece floor vs. 4 piece, different seating/bench position. I've checked many forums but can't seem to find any info. I'd like to do this on a budget and don't particularly care to buy new. Any information or plans on this project would be muchly appreciated! Thanks in advance.
pistonbroke
Re: MK2GR Floor Plans
Not much response on that one, so I'll ask: are the floors tight to the transom and tubes all the way around? I'll try my best to get a measurement and go from there.
deejaycee_2000
I don't have plans or sizes for you but ..... yes the floor are tight to the transom and tubes all the way around ...... it must be a really tight fit, put in the floorboard when totally deflated .... also make sure you seal the floorboards froperly with a good marine wood sealer eg. glatex 8 etc. ....
pistonbroke
Thanks very much for the reply. It gives me a good starting point now. The plan is to use 5/8 marine grade plywood bull nosed (rounded) edges finished with a few coats of marine paint leaving a hole up front for the inflatable keel. I'll probably built some benches in afterwards. Thanks again.
