model of engine
rosgood14
i have a 1971 penn yann with the original motor in it i believe. im trying to find out what kind of motor it is exactly so i can find parts. i know it is a 71 and it is a industrial ford model according to the number. here is the number located behind the distributor. D1JE-9425-AA
any help would be appreciated. thanks
Bt Doctur
Re: model of engine
Magic? Dont believe what you think you may have. Post some pics
rosgood14
Re: model of engine
sorry it took me so long to post pics, but here they are. she looks a little rough because the previous owner left the motor open to the elements.
Howard Sterndrive
Re: model of engine
D1JE-9425-AA = Mustang and Shelby intake manifold 302 Marine 4V according to the interwebs
sure looks like a 302 Ford
rosgood14
Re: model of engine
what do you mean mustang and shelby intake manifolds and where did you find out that it is a 302. thanks for the help
rosgood14
Re: model of engine
wow i fell like a dummy i searched all kind of sites but never thought to put the model number into google. thanks
Don S
Re: model of engine
I just did the Google and found the first answer the same. But if you look at the manifold, there is a question mark.
Then, if you look at this link, you find the number doesn't say that.
http://www.mustangtek.com/FordDecode.html
The engine however looks like a Mercruiser, and in 71 Mercruiser only used the 302, not the 351.
It's also impossible to tell from your pictures if it's a staight inboard or an IO with a jackshaft. I assume the latter from your pictures, and would think the setup is a 215E Mercruiser outdrive with jackshaft.
rosgood14
Re: model of engine
it is a inboard not an I/O. im not going to lie that link is a bit confusing to me. all that i can get off the model number is that it is a 1971 ford industrial motor. so how do i find out if it is a 302 or a 351 if the other information on google is not correct. thanks
rosgood14
Re: model of engine
could you possibly tell me where this casting number is locate because i can tell it is by the oil pan but i cant seem to find it not that i have a lot of room to look, but if i knew what area it might help. thanks
windsors03cobra
Re: model of engine
I can tell you that late model oil fill cap valve cover did not appear on a Ford engine till around 1985 with the advent of EFI so either you got a replaced late model valve cover or maybe a not original engine. 302's and 351's both had that style valve cover too.
The easiest way to tell the difference between a 351w and a 302w without having to take anything apart is to look at the surface where the distributor mounts vs. the flange where the intake rests on. On a 302, those two surfaces are relatively flush. On a 351w, the intake flange is about one inch higher than the distributor mount surface.
