Texasmark
- Joined
- Dec 20, 2005
- 14,795
As I mentioned a couple of days ago (OB non repair disc), boy's 150 BM has the pee routed from the output of the stats (2). That forces you to wait for pee till the stats open.....not good.
Found out that the (a) 200 hp BM has strong pee from the start and after talking with the owner (forgot his name) I find out that he has the output of the cooling channel and the stats plumbed to the pee spiggot.....from the factory.
Looking at the engine yesterday and noticed a 3/8 water line coming from the top/rear/center of the engine, immediately astern of the flywheel's safety cover, that routes down the starboard side of the engine and exits into the exhaust channel below the lower cylinder on that side. I assume that it is a vent to insure that air pockets don't form at the top of the engine causing spot overheat problems. I further assume that there is a constant flow of water out this port as long as the impeller is pumping.
Gonna bet this is the line that the 200 has added to the stat line go get instant pee. Any takers on the validity of that assumption?
What I thought about doing, since we are relocating the pee spiggot so that it's easier to see from the helm, is to put 2 outlets on the side of the engine. One to tell you that the impeller is a pumpin and the other to tell you when your stat(s) open......course, thinking as I type, that's not all that great, as one could open and one could be stuck and you probably wouldn't know it till one of the OT sensors closed which is the same situation you'd have if you weren't monitoring stat output at all.
I think we will remove the tee from the stat output and if the hose is what I think it is (mentioned above) put it (the tee to the pee spiggot) in that line and just plum the stat output straight through to the exhaust with no tell-tale on it.
Comments, suggestions appreciated.
Thanks,
Mark
Thanks,
Mark
