I have 2 props for our 20' pontoon. 1) 14-11 3 blade and 2) 13.25-13 4 blade prop.
RPM (from dash tach, so take it for what that's worth) w/ the 3 blade is about 5300.
from the 4 blade about 4700
Engine range is 4500-5500 so both seem to be within range. Optimum is 5000.
Now I called our local prop shop and apparently they suggest a different prop if I wanted to change anything. I have read that props can be modified but unsure (these are aluminum btw)
NOW IF I wanted to attempt it and could find someone to do it would it be possible to modify either the pitch or the diameter of the 4 blade (Solus Rubex if that matters) I like the cruising range response of the 4 over the 3 though this could be psychological, and it does seem more fuel efficient..
One problem common to both but seemingly more pronounced on the 4 is ventilation at full throttle (seems mostly trim related though but I'm still in the playing stage of finding out the cause).
I'd prefer zero over-speed/lost power issues w/ full throttle but the engine is as deep as it can go and don't have anywhere to start on solving this issue anymore. I was actually hoping the smaller dia. 4 blade would have fixed this (it didn't). Just replaced the trim gauge as well so unfortunately I can't compare old blade trim position to new blade trim position.. can't be sure the gauges read the same.
Back to the orig. question: My gut feeling is I could reduce the dia of the 4 blade to say 13".. Or is it best to change the pitch to 12? Shooting in the dark here so any suggestions based on what I wrote would be appreciated.
