Re: moisture in the house
Check for any source of the additional moisture, leaks in roof, windows or plumbing<br />.<br />It has to be coming from somewhere.<br />Always use exhaust fans in bathroom while showering, kitchen when cooking, and laundry area while washing. The burning of natural and lp gas will also release suprisingly large amounts of moisture into the home, if it is not vented properly. Don't use those silly "energy saver" clothes drier gadgets that vent the air into the home.<br /><br />Newer construction and the emphasis on saving energy, have created homes that do not breath and allow the exchange of inside air for outside air. Any cool or cold spots will become wet with condensation. Outside walls in closets or behind furniture where there is no circulation will get wet and start to mold and mildew. Also of concern is any carpeted area with concrete underneath.<br /><br />I have seen new apartment/condos that vented the shower fan into the dead space between floors, causing water damage to the apartment above. Also seen clothes and shoes molded after only 4 months on the floor of a carpet over concrete floored closet.<br /><br />Have also seen holes/cracks in window frames, walls, and roofs, that leaked water into the wall cavity. Then the moisture finds its way into the living area.<br /><br />Gotta find any sources, and vent out the moisture and humidity.<br />May need to call in a professional.<br />Might want to start with the local power company, and have them come out and do an energy audit.
