Molylube Alternative
OptsyEagle
I only use a little dab of this stuff on the driveshaft splines of my 1976 15Hp motor. I got some when I ordered a water pump kit many years ago but have since used up that little supply. Any idea where to get this stuff. Is there a permatex substitute or any other brand name. I suspect it has to hold up to high heat.
F_R
Any auto parts store can fix you up with a tube of moly grease. Comes in a tube for a grease gun
Chris1956
Wait, I once heard said that "any grease is better than none". In all seriousness, I have been using regular marine grease for years, in a salt water environment.
jakedaawg
I also use triple guard for just about everything other than the hinge pin in my snow plow.
