Monterey 276 1996, reliable??
dluvpauline
I am considering the purchase of a 1996 Monterey 276. it has a single 7.4 motor. Can anyone offer any experience or insight into whether these boats and their motor/outdrives are reliable and a good value?
tommays
Re: Monterey 276 1996, reliable??
Well i am guessing it has a merc bravo drive :confused:
Is it trailered or used in saltwater :confused:
In general there are no big problems BUT it really depends on how it was used and serviced
Tommays
dluvpauline
I believe it is a merc bravo. I will confirm tonight after the test drive. It is in a wet slip here in OC and has been so for the past 5 years. The guy that is selling it uses it regularly for fishing.
dluvpauline
Just to confirm it is in salt water.
I asked how many hours were on the motor and he said he was not sure since it did not have an hour gauge. Would it not have come with one? Does this mean someone removed the gauge? he says he has put less than 400 on it since 2001.
tommays
It would be best to find out the serial numbers on the drive and motor one of the pros should ba able to tell exactly what you have
The matiance records are the only way to tell what was done over the years
But in general is the boat raw water cooled or fresh water cooled
It would have a heat exchanger with antifreeze if it was fresh water cooled
A boat that was used in saltwater for that amount of time is going to require far more matiance than the same boat in a freshwater lake
Tommays
tashasdaddy
hour meter is a option. many boats don't have one.
