Gary Tuthill
- Joined
- Jul 1, 2001
- 16
Hello Again: Started reviewing posts here and found out the above motor also has reed intake valves. My (limited) experience with these are that they are prone to breakage and changes in stiffness? If so, should I consider replacing these prophylactically on a 19 year old motor? It seems to run fine at speed but tends to hiccup at idle or during early acceleration. Seems very prone to 'loading up' if left to idle for any time at all. New surface gap NGK plugs installed. Other than the obvious items such as lower unit grease, is there anything else (fuel pump, water pump, lower unit seals, etc.) I should repair/replace now. I prefer avoiding rather than dealing with a problem. I'm still planning on replacing the motor with a four stroke eventually but for now would like to continue using it (financial reasons). Thanks again! Gary Tuthill<br /><br />New (to me) mint '82 Glastron SSV-151 25th Anniversary Edition, '82 Mercury 90HP L6
