I have a 1989 70 hp evinrude pushing a 17 ft bayhawk -very small tunnel, basicly a flat bottom. I am running a 15 pitch rapture 3 blade and have smart tabs. Due to fishing in extreme shallow water I run this motor with the propshaft about even with the bottom of the hull. I have a remote water pickup so cooling is not a problem. Hole shot is awesome when it bites and I can trim the prop higher than the bottom of the boat at speed without losing bite. However, I want to raise the motor higher for getting on plane in shallower water. I added some cup to this prop, but I guess my question is would a 4 or 5 blade be a lot better or can I make the 3 blade work? Thanks
