dnifedem85
- Joined
- Sep 14, 2008
- 62
I, like many, took my boat out of hibernation today. I have a 1996 Johnson V6 Carb. 150hp motor. I throw on the muffs and she starts right up for me. Lots of smoke coming out. I assume this is normal? Just burning of all of the fogging oil, etc. that I used to winterize it. After 20-30 sec. of running, the engine shuts off. I try to start her up again and all I hear is the spinning of the starter, nothing happening with the engine. Same results time after time. I clean all of the spark plugs, check all of the connections and everything looks good. Does any one have any idea as to what could be wrong? Thanks for the help!
P.S. When I shut everything down and tilted the motor, some kind of black oil started draining from the lower unit through the propeller where the exhaust leaves the motor.
