more power
speed5
I have a 115 hp is there any performance tricks to make this a faster running motor
Dhadley
Re: more power
Welcome!!<br /><br />Depends on what rpms it capable of now. I would bet the answer is yes but we need to know more about your set up.
speed5
Re: more power
the motor is on a 16 and a half foot boat motor runs like a top just woundering if maybe a larger carb or i even herd that you can put a 140hp exhaust cover tobring up some ponys is this true
Dhadley
Re: more power
Well, we still need to know where we're at to start with. What is the top rpm with an average load?
Dhadley
Re: more power
OK. We're not taking full advantage of whats available now. Lets work on the set up to maxamize whats there. <br /><br />Post the top speed and what prop youre using. We'll calculate the slip % and see what we can do. Also post the hull type and your intended use.
