Ok... for all of you who havnt been following me.<br />1996 16.5 fiberglass starcraft tiller ( STERN HEAVY)<br />1984 65hp comm evinrude (transom rating maxed)<br />all results are tested in alike circumstances.<br /><br />Results 1 OMC 13 3/4 x 15 aluminum<br />30mph @ 5800 RPM's (fair hole shot)<br /><br />Results 2 OMC 13 3/8 x 17 aluminum<br />32mph @ 5900 max RPM'S (poor hole shot)<br /><br />Results 3 SST II (used) 13 3/8 x 15 Stainless<br />32mph @ 6200 RPMS (over limiter) very good hole shot<br /><br />Results 4 SST II (NEW!) 13 3/8 x 17 stainless<br />33.5mph @ 6100 RPMS ( this prop has drilled vent holes and provides a fair hole shot.) excellent mid range acceleration.<br /><br /><br />My confusing starts with. i thought im suppose to lose rpms when going to stainless? im gaining way over my max rec rpms.<br /><br />The rule should go that i should move up to a 19 pitch prop.. but i will have virtualy no hole shot. The boat is very stern heavy and does not make it on its pad. ever. <br /><br />Should i look for a 17 pitch prop that will lower my max RPM's? or go to a 19pitch + trim tabs ? <br /><br />any recommendations will be appriceated...
