More Seapro props
boling
115 HP Johnson, Seapro 180CC, 14x17 Al prop<br />I got 42 Mph @ 5800 GPS (setup from the dealer)<br /><br />This weekend I got the chance to try a SS (remanufactured, not sure what type, 389510 stamped on the hub) It seemed to slip (motor rev up slightly) a bunch while planing out. Reached 44.7 @ 5700 on very smooth water. Have I a bad hub, or is my setup very close to being too high for this prop? What effect would diameter have on X-demension I can run? Is it possible that the Al 14X17 hooks up better than a SS 13x19.<br /><br />Sorry for all the dumb questions.
walleyehed
Re: More Seapro props
13X19 will not run as high as a 14" prop will.<br />The prop being rebuilt doesn't mean the right amount of cup was put back in either.<br />If it has a true 19 pitch and proper cup, it should have dropped more RPM.<br />Your slip ration went from 10% with the 17, to 12.8% with the 19 SS, so I know the prop has not been rebuilt to specs.<br />The 389510 is an OMC SST.<br />I think you would get better numbers going with a high quality SS in a 17 pitch.
boling
Thanks Kenny. What brand should I save up for? Will it have to be a 14" diameter at my motor height?<br /><br />Thanks for the help!
boling
took the SST in and got a Rapture 13.25"X17" without the plugs installed.<br /><br />Here's what I got:<br /><br />5800 RPM and 44.7 MPH GPS. Still vents a little, but not as bad as the SST.<br /><br />Thanks for all the help!
