Re: More Smartcraft Issues
I think I found the answer on another website. There is code (microcode) within SC1000 gauges that has been updated from time to time. My SC1000 monitor comes up with a "3.04" displayed initially. This, no doubt is the microcode version number, and the monitor will only talk to engine PCM's that are at a more current microcode level than my 2001, unless I get a code upgrade which can apparently be done if I send the PCM back to the factory. I'm now in the process of determining who or where to send the PCM, how long it would take, cost, etc. but I'm beginning to wish I hadn't started this whole thing. I expect there will be further complications since I think Smartcraft technology was owned by VDO which was owned by Siemens but has since been spun off, and Mercury is now owned by Brunswick. Question: Is this really a better solution than a few analog gauges (fuel, voltage, water pressure, engine temp) that one could read at a glance, even while running at WOT, instead of having to page through an LCD display?
