more speed
hitace
i was just wondering everything i could do for more speed i have a 20 foot 2007 sea hunt it weighs 1900 pounds with a 150 HP 2001 johnson 2 stroke outboard ocean pro. aluminum prop 15x17 and running 5100 rpm at wot (45 mph) under normal load any help on how to get more top speed? thanks.i know the motor it self looks like it should be raised a hole or 2 it looks a little low.thanks.
tashasdaddy
Re: more speed
AV plate should be 1 to 1 1/2 above the keel and horizonal to the keel. some go 2 " but watch the water flow. that high and i would want a water pressure guage.
Chinewalker
Re: more speed
Might be a little speed in getting it properly propped. You want the revs to be peaking just on the far side of 5500. 5100 is too low, so you'll want to drop a little in prop pitch...
- Scott
Bob_VT
Re: more speed
Simple.... go stainless steel for a prop. :)
hitace
Re: more speed
anymore sujestions?i know holley offers a nice outboard Nitrous Oxide Systems.which will give 40% more H.P. for a few secs
Frank Acampora
Re: more speed
Oooh--If you have it, post the websit for the nitrous system. Been wanting to put one on an o/b for a while.
hitace
Re: more speed
i just wanted to do all the fine tunning to get evey mph out of my outboard before adding nos.any more suggestions.thanks
Bob_VT
Re: more speed
Get a smaller lighter boat.
