i made a post earlier today because my starter wasn't contacting the flywheel. i lubed up the gears with WD40, cleaned all connections, and put the batt on to charge for about six hours on 2 amps. just put it back in and tried it again and now the starter will engage the flywheel, but the flywheel just kinda "pulses" or "chugs" round and round slowly. is this still a battery problem? i just got the motor put back together from a piston, rod and bearings change and boring on one cylinder. when i turn the flywheel with the nut, i can feel some back pressure, but no binding or anything. just compression as far as i can tell. by the way its a '79 rude 85. thanks again in advance.
