greenygreen
- Joined
- May 13, 2014
- 48
from the top, bought a tn28 2 years ago. it had new coils, impeller, gaskets and i rebuilt the carb. fuel lines clear and new spark plugs which i changed just before the problem and they were not the right plugs that came out . just put float in today but didnt change anything,. when i took it first trip this year the clutch spring was broken so i ran it for about 20 mins at idle then fixed the spring by using the 3/4 of it that was good. anyways when i put back in the lake i have lost all high rpms. NO sputtering just a steady 1000 rpms at most. im sure fuel system is good and compression was good. high speed needle and butterfly seem to be acting normal.RUNS GREAT IN A BUCKET but wont pick up when boating. i cant tell any difference in anything but rpm. purrs like a kitten just lost its growl. it used to plane the boat out with a 60lb battery in front..
