I am trying to figure out why my shifter is stiff from forward to neutral.
I installed a new MT3 Morse control binnacle to use w/ my twin '89 Evinrude V4120's. One engine is perfect. The other is stiff to shift from forward to neutral. It is smooth going into forward or reverse from neutral. It is also smooth shifting in and out of gear w/ the engine not running (while rotating the prop).
Any ideas why this would be? I have gone thru cable alignment several times, and pretty sure it is as well alligned as the other engine. Could it be related to rpm's?? I'm scratching my head on this one. It gets very stiff as you bring it from the forward detent to neutral, and alot of times once it does shift, it goes straight into reverse, and I have to bump it forward again into neutral.
Any ideas?
Any ideas?
