I recently bought a '97 Johnson, 6HP;J6RLEU.<br />When I tilt the motor up, using the hand hold at the rear of the motor cover, the latch attached to the lower motor cover moves forward, and leaves an opening where the starter rope enters. This is not only noisy, but allows salt water spray to enter the motor compartment. And the cover cannot be removed until the latch is levered back into place with a screw driver. Both the upper and lower catch mechanisms appear to be OK.<br />Is there a fix for this problem?
