Re: Motor Cover Restoration
I just went through this. Here is what I did:
-used heat gun to heat and scrape off old decals. Can be done with hair dryer. Be careful here. I had to use a window scraper razor blade to get underneath, but it is easy to gouge fiberglass. You can try a paint scraper.
-fixed gouges with marine epoxy. sand area smooth with 100 grit
-fixed small pits with automotive glaze putty (spot putty).
- Wet Sanded whole thing with 200 grit
-wash with dawn soap
-wipe down with denatured alcohol.
-used a automotive sprayer and sprayed industrial "Alkyd Modified Acrylic Enamel" ($11 quart at Industrial / automotive paint supply). Do not waste your money on those "johnson" ready to spray paints. They are acrylic Laquer and don't hold up very well. Just take your engine cover to the supplier and they can match the color. Be sure to get the hardner for the paint. I did not do this and it takes a week for it to harden. You will get better results with a hardner.
-bought a decal kit on ebay and applied with spraying soapy water on back of decal and motor, then let dry.
ENGINE COVER LOOKS BRAND SPANKIN NEW!!!
