Hey everyone,
My 1981 75hp Evinrude dies when I put it in gear. I have rebuilt all three carbs, set the timing, synchronized, all by the manual, but when I set the idle to the recommended 700-750 rpm in gear in the water and unrestricted the motor will die. WOT is great top out at 5000 rpm, good acceleration, planes out good, no hesitation or bogging down when I full throttle out of the hole. Compression is 120 on all three cylinders. If I set the idle to 900 rpm in gear it will not die.
I am using the console mounted tachometer to set the idle rpm. How accurate is this type of tachometer, are there any variances in there readings.
