hey. ive read a few threads with similar issues most say to adjust the idle mixture and clean the carbs. i have a 1985 50hp force. the idle screw is in the top front of the carb correct? and also when my motor doesnt decide to die on me and i get to cruise it runs just fine but when i hook a tube to pull it seems as if the boat cant haul the tube it goes about 5 mph and the front of the boat sits really high in the air. once the person gets off the tube the boat goes just fine. is there a way i can adjust the max rpms to make it run a little faster. after about 5-10 mins of cruising with somone on the tube it eventualy evens out and glides across the water like its not hauling something but the first 5 mins it just drags.
---mike
---mike
