sphinx6060
- Joined
- Apr 13, 2007
- 9
1977 Johnson 55hp
Started my boat Sun morning at my house and it started right up.Took it to the lake and nothing.Smelled like it was flooded. Took it home and took out the plugs and spun it to dry out the motor. Got it running and then took it to the lake and it ran just fine. Stoped/started and ran all day just fine. Took it back out to the lake this morning, got it in the water and nothing. Smelled like it was flooded again. Took it home and pulled the plugs mulitple times and spun the motor over to clear it out. Never did get it to run so I left the plugs out so it would dry. When I was at the lake I trim'ed the motor up to reach the plugs and noticed the fuel was pooling in the front cover(coming from the carbs). Im assuming one of the floats are stuck(or miss adjusted) and Ill probably need to rebuild the carbs but I wanted to check on here first cause I might have miss diagnosed it. Worked on cars for a living for a long time now but Im new to boat motors.
