motor guide troubles
georgiaboy
I have a 2005 motor guide digital fresh water series 71lb thrust. the motor stored working so I checked everything I knew how and found nothing. So I finally got mad and slamed it down into postion and it started working. Then today after it set awhile it would not work again so i slamed in down about 4 times and nothing. Any ideas? Also will the motor run when it is in the up and locked postion?
