Motor idels great but bogs when accelerating under load
tpenfield
Re: Motor idels great but bogs when accelerating under load
Welcome to iBoats . . . very good idea about posting a video . . . it makes things soooo much easier.
That engine sounds 'interesting' . . . valve noise maybe? I would run a compression test and even a cylinder leak test, just to see what is going on from an internal perspective.
danielw71
I am going to try to get the gauges to do that today.
Yesterday I tried spraying carburetor cleaner around the intake to see if it was sucking air and it is not.
I took the fuel pump off and looked at it and the filter and diaphragms are fine too.
A few weeks ago I took the fuel line off of the tank and put it into a gas can full of fresh fuel and it did the same thing.
I will post the results of the pressure test as soon as I get it done.
I would think if there was a bad cylinder it would be hard to start or run rough all of the time, it starts right up and idles great the bogging only comes in under acceleration.
MBAKER
maybe double check that plug wires are in order?
danielw71
Thanks, I will check when I get home but I am pretty sure they are right:
1-3-4-2
danielw71
Yes 1-3-4-2 wires were right
still trying to get my hands on guages for compression testing
danielw71
I took the distributer apart down to the advance weights and it was dirty and tacky. I could move the weights but it was not easy, so I cleaned them up, put a couple drops of 3 in 1 oil and put it all back. For the first time I could accelerate without the bogging I have not put it on the water to be sure. I will let you know if is all worked out. Thanks again.
garbageguy
Did that resolve your issue? I have a similar situation.
danielw71
Yes!
I am sorry i did not get back sooner. I went out and was pulling two tubes and had no trouble, its running great now.
