Re: Motor idles, but bogs down when you speed up
Hi, <br />Can't help but to be sympathetic. I had a similar problem that I played with for 3 weeks. It was a 70hp 3 cyl Johnson. Turned out to be a piece of silicone (like caulking) stuck in a main jet in one of the carbs. In my case the 3 cyl ran well enough to idle and troll on 2 cyl, but bogged out when it was throttled up. It was a hard thing to find as the silicone was stuck and was clear so it was hard to see. Yours sounds like a fuel problem to me, so I wouldn't waste time on changing props, gas tanks, primer bulbs etc. unless they are obviously not working. I did this and just spent money and time for nothing<br />I suggest you try following.<br />1. Check compression on cylinders If all OK then,<br />2. Idle in bucket or with earmuffs and pull spark plug wires one at a time. If one cylinder makes no difference then,<br />3. Check spark plug on bad cylinder, if ok then<br />4. Move a spark coil from one of the good cylinders to the bad one if it makes it work then it was the spark coil, get a new one, if no difference then it is a fuel problem from the carb on that one cylinder<br />5. Take carb apart and thoroughly check it out, particularly the main jet. Do whatever it takes to ensure it is not obstructed including carb cleaner/soak, compressed air blow etc.<br /><br />Maybe this will work for you.
