I had a 1988 125HP motor that developed a water leak in #1 Cylinder. Tried for months to fix to no avail. Had block and head machined, but didn't do any good. Came to the conclusion that leak was somewhere in the crankcase itself. Ended up getting a 90's 120HP block. Put the internals from the 88 into it with new bearings, seals etc. Had it bored .020 over, new Weisco pistons. Runs great now. Made a few of the following changes.
Added a temp gauge. Mounted sending unit here.
Added a water pressure gauge. Found a pipe plug in the exhaust plate between the motor and lower unit that leads right into the water passage. Took plug out and installed a brass fitting to attach tube to WP gauge.
Had problems with overcharging. Removed the recftifier assy. and installed a rectifier/regulator. Fashioned an aluminum plate to mount the rect./reg assy. on and bolted it to the block. I also installed a fuel pump from a late model motor.
This is how I wired up the new rectifier/regulator assy. I installed a terminal strip where the old rectifier assy. used to be mounted.
