Ok, so the lag screws pulled up outta the motor mount boxes due to an accident on the highway. I pulled the engine today and thought all I was going to have to do was drill the existing holes and epoxy dowels in them to hold new lag screws. Well, once the engine was out and upon further inspection, I found that the port side mount box is broke loose from the hull. I cut the fiberglass around the box and removed it. I went to a wood working shop today and baught the epoxy for doing the dowel job, and I am wondering if I can use this same epoxy to re-adhere a new motor mount box to the hull. The guy at the store sold me west sytems g-5 epoxy adhesive.. Will this work or do I need to take it back and get the 105 epoxy...
This is turning out to be a bigger nightmare than I thought..
Thanks
Thanks
