FuelishBehavior
- Joined
- Aug 7, 2012
- 139
I believe I've asked this before, when changing out engines, I've read you should remove the lag bolted mounts. I am doing this due to the fact that the adjustable mounts are completely rusted out anyways. When putting the mounts back on the stringer however, do you just use longer lag bolts or do you fill in the old holes with some kind of filler so there is some meat for the new lag bolts because I assume you'll need to put them back in the same location.
