Motor Mount Placement
mtnrat
I am putting in the motor mounts for a volvo 280 leg with a chev 350 in a full resto project. The previous owner did a partial resto and replaced the motor mounts and they were put in a little askew. What I need is the distance from the transom wall to the centre of the mounting stud in a line. Also I would like to confirm that the width centre to centre is 22 1/2". Does anyone have a diagram for this?
mtnrat
Re: Motor Mount Placement
I figured out a solution. I remembered when I did this on my last resto I put the mounts on the engine and lowered it into place, bolted it to the transom shield, and aligned it, Then I took my angle drill and drilled the holes and lag bolted the mounts in place. Worked perfectly last time.
