motor mount question 5.7 vs 7.4
Cptkid570
Ensign
If a boat has a 7.4 mercuriser, will a 5.7 liter mercruiser bolt up to the same motor mounts or are the motor mounts in a different location for a 7.4 than 5.7?
Reel Poor
Re: motor mount question 5.7 vs 7.4
The drive is a different gear ratio and the front mount location on the stringers is slightly (a couple of inches)closer to the transom.
Cptkid570
Ensign
Would the front engine mounts be the same height for both?
Ayuh,...
I just dug out a Merc. Installation manual....
It says,...
The motor mounts for Both motors are 19, 15/16" from the foreward mounts to the aft mounts....
And,..
Both motors are 22, 1/2" between the front mounts,...
And,...
The mounts are equal to the crankshaft centerline.....
So,..
In theory,... They'll Both drop into the Same Holes.... Your results may vary......;)
Cptkid570
Ensign
Thank you for your responses everyone. I really appreciate all of the help.
I currently have 2 boats. A 19' bowrider that is running rough (I had a different post on iboats about that yesterday) and a 26' boat that I don't really like, but love the engine... I want to find a 23' or 24' boat to put that engine in.
So, that's why my name seems to be popping up a lot with bunches of questions.
Ayuh,... No Problem,...
You Forced me to teach myself something this morning.....
Ayuh,... Had to drag out the Book,+ Look....
I'd have Thought that the BBC's mounts would be slightly forward,+ Wider...
Cptkid570
Ensign
Me too. Only reason why I thought they'd be close is because so many boats come with the option of a 5.7 or 7.4 engine. I figured the boat manufacturers wouldn't want it to be too much work in putting either in.
dan t.
this is an example of chevy interchangeability, all small blocks,all big blocks,same bellhousing,same mounts
