gurglegurle
- Joined
- Mar 7, 2008
- 2
Hi guys. I've been trying to figure out a fix and need your assistance.
I've had no luck with the seach function.
I have a 20' 1991 Ski Brendella in-board direct drive PCM 351 motor.
The engine is creeping up and toward the bow. The lag screws holding the motor mounts to the stringer are coming loose. The screws will not grab the wood anymore because the hole in wood is already loose-threaded or morelikely the stringer in the particular location is rotting.
My question is how to I go about a proper repair job to firmly connect the motor to the stringer so I can ski this summer?
I've had to redrill other locations for my pylon because of similar issue.
My best plan so far is to use angle iron to sandwinch between mounts and stringer using new hardware and drill new holes.
I'll try to take some pics. Thanks for any insight and help in advance.
