What can I do about my outboard motor that is not running hot enough? I have a 1962 Evinrude 40 h.p and I just installed a temp gauge and sending unit on it. The gauge is reading about 105 degrees F. I think it is pretty accurate as I am seeing the rainbow of unburned fuel and the oil is globbing up in little balls (at the discharge) the same as when I ran my motor without the thermostat in place. When I did that, the motor ran cold too and I had the same indications until I put the thermostat back in, then the fuel rainbow and oil globbing stopped.
I have these same indicators again today, and the gauge reads 105 degrees like I stated. Now the lake water temp is only about 40 degrees F at the surface. I know this probably plays a roll in the engine not heating up properly. Is this something I just have to live with until I store the boat for the winter, or can I get a differant thermostat in the motor to make it run hotter or is there something else I should do?
Thanks.
Thanks.
