Re: motor only pumps water in forward gear?
You might try this also:
Clean out the 2 small holes in the rear right below the lower cowl cover. These are idle relief holes that over time plug up with residual exhaust trash and force too much exhaust into the intake water tube during idle. You can clean out with a small wire and spraying WD40. If you are cranking in a barrel and in neutral, this problem really shows up.
Good luck, these are great little motors!
