Hello all,
I figured I would start a new post for my problem to maybe get some fresh ideas.
I have a 1985 OMC 1.6L SeaDrive Powerhead on a 115 Johnson mid and lower. Currently, My motor runs really bad with the engine cowling on. It spits and sputters and has a great loss of power. Sometimes it won't even plane off and when it does it has between 3 and 4k rpm. When I take the cowling off it is like I unleash a completely differant motor. When pressed straight to full throttle, for about the first 3 seconds after running it with the hood off it acts as if the carbs are flooded. Then, it takes off and runs like a top. With the hood off it will do 5700rpm and 44mph at WoT, but it stills seems a bit unsteady at just above idle up to 3/4 throttle. I did take off and clean the carbs. The change from running nice with the housing off to running crappy with it on is almost instantly. Orignially the latch to the cowling in the back left was scrapping the spark plug boot and I believe shorting it out. When I first figured this out, the motor ran great with the other two latches clasped and the back left off. But, after only half of a fishing trip, the leave the latch off trick also no longer worked. I also notice that excess fuel is in the bottom of the motor housing and I have a decent amount of unburned fuel draining from the motor housing at the bottom and also at the prop.
I searched the forums and found potential causes as air flow into the cowling restriction, exhaust leak into housing compartment, and shorting/grounding out of one of the plugs or coils.
What do yall think as a possible cause, and what are the ways to test the probable causes?
I do know that the head has a small exhaust leak from the bottom of the head near the middle (maybe the base gasket). The leak isn't really bad, but do we think this could be the culprit. I was thinking that the exhaust leak wasn't the problem because the change in power seems almost instant when the cover is placed on.
I also don't know it having a omc seadrive powerhead under a 115 johnson hood is a possible cause. The cowling seems like it doesn't have enough clearance. Does anyone know if there are many differences, especially in design/size between the johnson 115 and the 1.6L omc seadrive.
Thanks for your time and help,
Scott
Scott
