Re: Motor Position
Most pontoon boats come with a transom saver for the same reason you use them on a "boat".
owned 4+ pontoons, on both bunk trailers as well as scissors. Have helped friends and family with probably another dozen or so 'toons. Not a SINGLE one has come with a transom saver. zero. Not even sure how you would attach them to a pontoon trailer.
MOST pontoons will require towing with the motor up, otherwise the lower unit skeg is going to be dangerously close to the ground. (keep in mind how long a pontoon is, and that a small speedbump at the tow vehicle can translate into a lot of vertical movement at the skeg.) Pontoons must have transoms that are 10x stronger than a boat though, because given the above statement of pontoons not having transom savers, I have yet to see a motor fall off the transom from towing.
