motor question
jimmy wise
hi, my boat has a 898 305 i believe its a mc-1 out drive. i have no history on the 305 except it is very clean in the valve cover. rusty in the exhaust ports on starbord side. port manifold is missing. i can tear it down to see if its rusty or i can put a 383 stroker that i have in a jet boat. its 4 bolt main and all. what cam specs are you recommending for marine. i am going through the out drive so do i need to improve on anything in side or just rebuild it. i know the 383 is a tork monster but was hoping cam specs are close...jimmy the upholsterer:lol:
jimmy wise
Re: motor question
also i forgot to ask should i change to later manifolds with center risers since im missing one and they are expensive for rear dump?
cr2k
Re: motor question
I'm thinking that a 383 would rip an MC-1 to shreds.
jimmy wise
Re: motor question
That's why I put it up.....I'm not sure. 305 is good on fuel
Re: motor question
Ayuh,.... It's hard to say, You don't mention it's Cam Spec's....
'n Nope,... There's Nothing you can do to "Beef Up" the MC-1,... It is what it is...
jimmy wise
Re: motor question
ok i think this is the cam spec it was from paw years ago .214 .214 .442 .442 112 jim
Re: motor question
Ayuh,.... Those look like reasonable #s for a marine application,...
If the 1st 2 #s were much bigger, or the last # much smaller, ya Might have issues...
Ya, you can do that,... But,....
You'll probably run into fitment issues marring the center risers to the Y-pipe on the transom,...
There's several different cast elbows available, but I'm guessin' ya might have to build yer own to fit...
With the Stoker motor, the MC-1 will be Ok, so long as ya avoid throttle slam launches, or catchin' Air, off waves...
When the MC-1 finally gives up the ghost, a brand new SEI Alpha 1 is only 'bout $1,500. 'n should bolt right on....
that's pretty Cheap, in boatin' terms...
