Motor removal?
urdarren
I have twin 305's and I need to remove one of them due to a hole in the oil pan. Went to remoce the starter motor and touched the oil pan and it started leaking.. anyway....<br /><br />Do I have to reomove the drive first or can I just pull the motor?<br /><br />Also does anyone know of a good web site to get cheap aftermarket engine covers I want to go ahead and replace the timing cover also...<br />I have twin motors if that makes a difference.<br /><br />Any help or links will be appreciated.<br /><br />Thanks<br /><br /> :confused:
almost retired again
Re: Motor removal?
Hi Darren,<br />Yes on most engine application you can just pull the motor, but your job will be so much easier both in and out if the drive is pulled first.<br />You can use automotive timming chain, valve covers, and oil pan from an automotive 305.
urdarren
Re: Motor removal?
Put them both back in today used a reach forklift which made things o very smooth not to bad putting them back in will finish up tomorrow.<br /><br />Started pooring down rain so we called it a night.
