Hello, I have a 1984 24' Aqua Patio pontoon with a 50 HP Mercury outboard. The prop that is on it is a Quicksilver stainless steel 3 blade, 48, 76228, A5, 13P. When I open the motor up the boat picks up speed for about 5 seconds, then I hear the motor sound change, it sounds like the motor revs up a few hundred RPM all of a sudden. The boat doesn't slow down, but doesn't seem to run quite as fast as it should be running, doesn't seem to be much load on the motor. At that point I can run it all day, it doesn't ever change at WOT. If I slow the boat down then go back to full throttle, same thing again, gets to a certain speed then motor sounds like it is over-revving. I'm wondering if I'm getting cavitation, and if the prop is not big enough for the motor and boat combination?
No tach on the motor, so I used a laser tach and it's difficult to get a constant reading laying on the back of the boat while running but I think after the motor revs up I'm running about 5100-5200 RPM. I don't know what speed the boat runs, forgot to check with GPS when I had it out last.
Does this sound like caviation? Any ideas if this prop is about right size? Other info you need to be able to give some suggestions?
Thanks, I appreciate the great info everyone shares on this board.
