MOTOR RUNS 4200 RPMS THEN DROP OFF
(2) 1992 JOHNSON 200 H.P. HAD WATER IN GAS. HAVE WATER SEPARATER. MOTOR RAN OK STRAIGTH BUT ON TURNING ITS RUNS BAD LOSING RPMS. ALSO THE BLUB GOES FLAT AS A PANCAKE. WHAT CAUSE BLUB TO GO FLAT? UNDER STAND WATER IN GAS? DO I HAVE A AIR LEAK? HOW TO CK FOR AIR LEAKS? OR IS IT SOMETHING ELSE. ANY IDEALS...
Joe Reeves
Re: MOTOR RUNS 4200 RPMS THEN DROP OFF
Having a fuel primer bulb go flat indicates that there is a fuel restrictiuon between the bulb and the fuel supply.<br /><br />Either the water/fuel seperator filter is clogged or there is a restriction at the fuel tank such as a sticking Anti Siphon Valve. Some of the following may not apply to your engine as this takes in the V/6 engines also. (See Below).<br /><br />(Fuel Anti Siphon Valve)<br />(J. Reeves)<br /> <br />Many of the later OMC V/6 engines incorporate a fuel restriction warning via a vacuum device attached to the powerhead. If the engine overheats, or if you have a fuel restriction, the warning is the same.... a steady constant beep.<br /> <br />NOTE... Only the V/6 & V/8 engines have the above "Fuel Restriction Warning". The warning horn will not sound on the other models. <br /><br />The fact that a engine is not overheating, but the warning horn sounds off with a constant steady beep, and that the rpms drop drastically would indicate that the engine is starving for fuel due to a fuel restriction. Check the built in fuel tank where the rubber fuel line attaches to the tank fitting. That fitting is in all probability a "Anti Siphon" valve which is notorious for sticking in a semi closed position. It will be aluminum, about 2" long, and the insides of it will consist of a spring, a ball, and a ball seat. If this valve exists, remove it, knock out those inner components which will convert it to a straight through fitting, then re-install it. Hopefully that cures the problem.
