G'day folks.
I've tried searching some of the threads to find some info about this, but I haven't really had any luck. I am totally new to having an I/O, as I have always had outboards instead. I recently bought a 17' Riviera bowrider, with what I was told has a 140 hp 3.0L Mercruiser. Is there a way I can verify this myself, serial numbers or anything like that? The engine is a 4 cyl. GM block.
Also, I believe the outdrive is an Alpha, it has a waterpump located in the outdrive like my old 75 hp Merc. outboard, and from what I heard, Bravo's have a belt driven raw water pump. What are the differences in the outdrives such as Alpha's and Bravo's, etc?
I guess this is also the time to throw in a question about props. I want to get a 19' prop for that outdrive as well, and the specs stamped on the 17' that's on it now are totally not legible. I want to know about the diameter of the prop, as I was hoping to use my spare prop from my outboard before I sold it, but didn't after noticing the difference in diameter. The outboard had a 13" diameter prop.
Thanks!
Thanks!
