robaloroger
- Joined
- Feb 16, 2010
- 123
lx250turz motor fires up and idles fine for a few minutes then as it warms up it idles very low then will stall. When it stalls the alarm beeps over and over(not constant)The alarm beeps 3 times when key is turned to the on position. I pulled the float out of the oil tank turned it upside down and it beeped constant(working) on board tank is pumping oil when engine tank is low(working). I do not think it is oil related but might be wrong. Motor pees a very good stream and is cool. I do not have any gauges. I am in the process of rigging these motors on a boat. The 2 plugs on the cylinder heads were missing. Maybe the previous owner was flushing the cooling passages. There is 12v at keyswitch.. The kill switch has 2 black and 2 whites but only 1 black and 1 white are plugged in. I used each keyswitch (dual)and got the same result
